Fitting Changer
Hi Guys,
I've an Octavia with a Grundig 411 CD Player/radio fitted. I've been given a VAG 6 disc Changer ( model 1J5 035 111A) made in Czech. I'm after the cable to fit the two together. (none fitted to the boot)
Anyone any idea of part numbers/where i can get one and if the two are compatible?
Any advice greatly appreciated.
Thanks.
Bri
On my website mate, in the handy part numbers section of technical.
Many thanks Stu. Much appreciated
I've now got the cable (thanks Stu). there is an extra brown wire that needs to be attached somewhere(fit in one of the holes in the 3 piece socket on the HU. Does anyone have the details/instruction wiring diagram. Any info welcome before i run off to my local dealer.
Cheers,
Bri
Sorry Bri I can't help you but there is a pin out diagram here -
http://www.fabia-vrs.com/carkit.htm
I'm sure if you call your dealer they'll tell you.
