CC not working - implausible signal and won't clear
CC was working when I took the Fabia out at 5 this evening, but stopped working when I've just gone out!
Gave it a scan and came up with:
Tuesday,01,March,2016,20:49:24:35773
VCDS Version: Release 15.7.3 (x64) Running on Windows 7 x64
www.Ross-Tech.com
2 Faults Found:
6117 - Function Restriction due to Implausible Message(s)
          U1112 00 [037] - -
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 139720 km
                    Date: 2016.03.01
                    Time: 20:43:22
6118 - Cruise Control Switch (E45)
          P0568 00 [037] - Implausible Signal
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 139720 km
                    Date: 2016.03.01
                    Time: 20:43:22
Readiness: N/A
Tried clearing but comes straight back. Had this on my Superb and the stalk needed replacing.
Is the stalk a DIY replacement?
Certainly would seem to be a stalk issue. Stalk is DIY providing you are ok with airbag removal.
Does the entire wheel have to come off to swap?
Yes, switch is around £90
Edited by Tech1e
Thanks Tech1e.
Am I right in thinking the part number is 7H0953503BQ?
Have you checked the brake light switch, iirc this is a dual device, for lights and cc control, often one side breaks hence the implausible signal error. Cheap and quite easy to replace.
The brake lights are coming on. How is best to check it?
Worth checking in advanced measuring blocks. But I wouldn't expect that fault code with a faulty brake light switch.
Can I use a 6Q0953503EJ with the 1.2?
