Will bad engine mounts effect biting point and gears
Hi all,
I have a 2011 skoda fabia 1.2 12v s and I'm trying to figure out whether my engine/gearbox mounts are gone or going or whether my clutch is going.
My skoda has only done just under 35000 miles 12k while I've had and gearbox doesn't feel as smooth as it did and I'm sure the biting point as moved up.
Many thanks
Hi, i'd suggest posting in the Fabia 2 section since you have a Mk2 2011 Fabia. if its a common fault someone in the that section would know better.
However, bad engine mounts would not affect the biting point on your clutch.
Edited by hutchysrs50
Thanks for your reply I apologise I didn't realise I posted in wrong section
