ABS Control module help.
Not been on here for a while expect browsing.
Bought an Octavia VRS pd170
6 months later I have every light on, on the dash. After scanning with Vagcom I'm getting no communication from the ABS Control module.
Done a bit of reading on here and other pages and it's looking like I need a new one.
Skoda are telling me I need to be 100% sure before buying.
The part is nearly £800 so I want to be too.
Is there anything else I can check other than fuses and plugs.
All help is greatly appreciated.
Send it to ECU testing.
Definitely start with the obvious, check the connections for any obvious damage/corrosion and the fuses. Assuming that's all good, make sure power/ground are making it down the loom to the ABS connector. Next check is the CAN bus wiring from the ABS controller to the CAN gateway.
Probably worth posting a full autoscan too :)
You can also get a good used module for much less than £800...
Thanks for the replies. I didn't get an email. So this is me now just checking it.
I've had all the cables, plugs and fuses checked. Everything seems good.
Mag
Who are ECU Testing ?
Langers
I'm not sure how to go about checking the Canbus stuff, although VCDS was able to access the other modules when I done the full Scan.
I'm on my phone just now. But I'll fire up the PC and see if I can post the full Scan.
Friday,12,February,2016,15:55:44:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.com
VIN: TMBEH21Z972107313 License Plate:
Mileage: 161910km-100606mi Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72
VIN: TMBEH21Z972107313 Mileage: 161910km-100606miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 EL HW: 03G 906 018 EL
Component: R4 2.0l PPD1.2 9802
Revision: --H42--- Serial number: SKZ7Z0F3974016
Coding: 0000072
Shop #: WSC 20025 576 92254
VCID: 73E247E312A68FA650-8026
1 Fault Found:
005705 - Powertrain Data Bus
P1649 - 009 - Missing Message from ABS Controller - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 5
Fault Frequency: 16
Reset counter: 40
Mileage: 161913 km
Time Indication: 0
Date: 2000.00.00
Time: 19:11:17
Freeze Frame:
RPM: 0 /min
Torque: 144.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 11.07 V
Bin. Bits: 10000100
Torque: 1016.0 Nm
Readiness: N/A
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3B72AFC37A7607E648-806E
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004672437
Coding: 01880F030004140000110D000000000000087F075C0000
Shop #: WSC 73430 790 00000
VCID: 6CD05C9F4F98505E91-8038
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 030107 022 0601
Coding: 00055223
Shop #: WSC 73430
No fault code found.
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0Z3TPC
Coding: 0020788
VCID: 3D76A1DB646209D676-8068
Subsystem 1 - Serial number: 6332MSME156B6363C
Subsystem 2 - Serial number: 6342MSME155E367DQ
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenks‰ulenmodul 036 0070
Coding: 0000012
VCID: 74E044FF17A8889E49-8020
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 912 E HW: 1Z0 920 912 E
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0F3974016
Coding: 0003401
Shop #: WSC 00011 888 96745
VCID: 377AB3F3465E2386AC-8062
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 134
Mileage: 161913 km
Time Indication: 0
Date: 2000.00.00
Time: 20:19:34
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 130107F1000630
Coding: 3D3F434007001303
VCID: 2F6A8B93BE0EEB46F4-807A
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 134
Mileage: 161913 km
Time Indication: 0
Date: 2000.00.00
Time: 20:19:36
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 134
Mileage: 161913 km
Time Indication: 0
Date: 2000.00.00
Time: 20:19:37
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000756
VCID: 3878B0CF4B402CFEA5-806C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3566B9FB5C52D196BE-8060
1 Fault Found:
00625 - Vehicle Speed Signal
004 - No Signal/Communication - MIL ON
Freeze Frame:
Mileage: 161900 km
Temperature: 2.0∞C
Voltage: 14.60 V
Voltage: 14.40 V
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 99801A085283007F3F04850540085F96907CA0
VCID: 030217234206BF2640-8056
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 134
Mileage: 161913 km
Time Indication: 0
Date: 2000.00.00
Time: 20:20:16
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 397EB5CB704A35F65A-806C
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0907
Coding: 0000144
Shop #: WSC 73430 790 1012544
Address 69: Trailer Labels: 1K0-907-383-MY7.lbl
Part No SW: 1K0 907 383 HW: 1K0 907 383
Component: ANHAENGERELEKTR 003 0020
Coding: 0000001
VCID: 6ADC5A87456C4E6EE3-803E
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
End-------------------------(Elapsed Time: 02:15)--------------------------
ECU tuning http://www.ecutesting.com/ are a company that offer repairs for ABS modules amongst other parts. They are well known for a G201 pressure sensor repair that plagued the MK60 ABS modules. Feel free to contact them but as you module isn't showing up at all it's almost certainly a different problem. Even if the ABS module is at fault they will need to diagnose it which is much harder when it won't communicate.
The CAN bus check will need a scope to view the signals on the CAN high and low at the ABS connector. It's to make sure there is clean CAN signal so if the ABS module were working it would be able to communicate with the rest of the car. I've included a couple of youtube clips which show some of the basics and what you'd expect to see.
If nothing changes once that's been checked and you're sure you have power, ground, CAN high and CAN low working, then I'd suggest a replacement ABS module. I'd probably grab an inexpensive used ABS module (£30-£80 I'd expect) from eBay or a breakers with the same part number as the current one and only connect it electrically to start with to see if that will communicate.
Thanks very much for that detailed reply. I'm away for the weekend. So I'll get onto it when I'm back.
I've been trying to source a used control module for the past 4 weeks and not had any luck at all. All the ones on Ebay have a different part no from mine on the module but the pumps are the same.
If you post the part number of the electronics module I might be able to tell you which modules superseded it to give you some more options.
That would be great.
The number I have for the module is 1k0907375AC
have you checked to see if the module plug has power and ground
no power or ground will shut the module down
BTW If you send it to ecutesting and they cant fault it or cant comm with it they just charge a nominal fee.
From what I can see 1K0 907 375 AC has no modules that supersede it.
It does look closely related to the 1K0 907 379 AC module and most the pre-FL octavia's I've scanned seem to have this fitted so I'd be surprised if it wasn't compatible. Plus they can be pretty cheap on eBay.
Cheers for the help and information. The 907 379 I had seen plenty of on eBay and wondered if they'd be the same but didn't want to gamble.
I've phoned ecu testing and they were also very helpfully. It's now getting posted to them tomorrow and fingers crossed they can fix it.
Thanks again to everyone that's commented.
A further Update here.
Ecu testing sent the unit back saying there was no faults.
Phoned a local Vag specialist who had another car on with the same issues and also had the module returned from Ecu testing.
They had an Auto Electrician in checking everything on both cars and have said it's definitely needing a new Control module.
Money waisted sending it to Ecu testing it seems.
