ASZ standard Overboost
Just recently had my Fabia VRS ASZ remapped from standard, one thing that was noted during the initial data logging was that there seemed to be abit of over boost low down the rpm range (2000 rpm). the boost pressure seemed to peak at 1.65 BAR at one point.
all the actuator, pressure relief and vacuum lines all seem intact and the new map has ironed out the over boost issue.
just wondered if any one else with a standard ASZ has had a similar issue or not?
Has the car had the cat removed?
the cat is still on the car and as far as im aware the insides of the are all intact
