Need help
Right ave got a serious problem oil seems to be disappearing a mean disappearing when a fill oil to correct line on dip stick the FULL LINE go to work do roughly a 100 mile next morning check the oil and it's down about 1/4 of the way on the dip stick.
No smoke
No oil leaks
New turbo
Even got kitchen roll wiped the inside of both exhausts nothing but totally dry carbon residue.
A use 5/40 oil from TPS
This has gone on far to long now don't no were to go next or what to do any help is needed.
This car is costing me a fortune in oil keeping the oil topped up.
HELP !!!
What engine?
1.9 pd
When was the last time you looked inside the fuel filter housing? The tandem pump in known to seep oil into the fuel, not usually as bad as you suggest but as you are struggling for option I thought I would mention it.
Sorry it's a 1.9 BXE.
Not long ago a did the fuel filter but cannot remember if it was black in there but well worth a look thanks could that explain why on tick over it absolutely stinks maybe thanks for the replys
could be worn piston rings,
have you tried adding something called engine restore additive as it is suppose to help to reduce oil consumption if it is your piston rings
NO never tryed anything like that.
It's as if the oil is just evaporating out of the engine can't understand it thanks
