Drivers door cable
Hi all
The locking cable has snapped in my Octavia I cannot open door anyone any ideas how to get door card off from the inside so I can open the door to replace cable .
I've never had the door cards off mine, nor have I really looked in detail, but I assume there are two bolts on the bottom of the card.  If the door is stuck shut, you may need to remove plastic trim from the cabin to get in.  Just guessing here though.
Thanks planehazza the problem is that the torx screws are on the side of the door but I can't open the door to get at
When you say the cable has broken can explain it a bit better
The lock has two attached cables
one to the inner door pull trigger
and the other to the outside handle
If one breaks you can still use the other
When I pulled the inner door handle the cable snapped so cannot open door. Tried opening from outside but no joy.
strange, maybe you have a wiring fault that has caused the lock to deadlock
try manually to unlock the car using the key in the lock, then try it from the outside
if that doesn't work
You will need to get the door card off
There are 3x screws behind the door grab handle
2x at the base of the door card
1x behind the speaker / mirror adjustment dial
the plastic poppers will give if you can pull on the door card
Cheers Eddie NL got it open will be able to get out drivers door now !! Thanks for that
