Traction control light issue !Help!
Hi just needed some advise my 2005 skoda fabia vrs has just recently started doing this, I will be driving for about 5 mins and the traction control light will come on and not go off until I turn my can off and on then will be fine for about 5 mins it's starting to annoy me now can someone please help me thanks.
Edited by Shardy96
A search would point you in the direction of broken DMF wiring to the alternator. I would hazard a guess you also don't have a battery light with ignition.
Check this connector in front of the gearbox
Yeah don't have a battery light and did search it up just wanted to be sure thank you do you know how I could go about fixing it if you can point me in the right direction thanks
Best way of fixing is to remove the connector and solder two short lengths of wire in its place.
