Mad Cross Country Springs on Superb Estate Outdoor Plus 4x4
I've seen a few posts from people who've fitted MAD Spring Helpers (usually caravaners) - but has anyone fitted MAD Cross Country Springs and if so did they affect the ride and help with towing? They are supposed to give you progressive loading with a 30mm lift (which would make the Outdoor Plus look more like the Octavia Scout or Passat AllTrack)...
and there'd be a reason why nobody has commented: Apparently MAD make Cross Country's for all FWD versions of the Superb Estate, but not the 4WD versions. Though they "think" that they'd work - they have advised against fitting them. Shame....
You can only load the tow ball to a maximum, so why do you need them, always better to be under by about 5 to 10 KG
5 people in the vehicle + all their luggage?
Rubbish roads?
Poor entry / exit gradings into driveways?
Hmmm. Cool. I have a 14 superb Kombi 4x4 170 now. But I also have bad road packet. 20 mm lift. Will these springs get my car even higher? Is this complete new springs?
  • 1 year later...
What's the "Bad Road Packet" is its Skoda accessory? If so do you have the part number?
I assume it is similar to what is offered on the Beetle?
