New to me fabia vrs
Well had my car in at garage today to give it a proper look over and there a nice little list of work to be done on it
NS drive shaft boot
NS anti roll bar link
NS OS lower arm rear bush
OS front break something stuck behind disk and back plate
OS rear caliper sticking or could be handbreak cable
All common faults and maintenance then really!
Calipers sticking is a common one, might be worth seing if caliper return springs will sort that.
Wishbone bushes usually get replaced with better options wush as PSB like i've used.
Ye by what iv been reading they all seem to be fairly common problems been quoted 350 for it all doing
NS drive shaft boot
NS driveshaft boot - around £50
NS drop link - about £30
NS + OS Wishbone bushes - expect anything from £100 to £200, people do it different ways and it can be a chew, just hope the front bolts come out ok and dont damage the consol that the bush sits in, then things get costly!
OS front brake - Depends what it is, backing plate pulled out the way more than likley - Free
Rear caliper - If they use a new one they can get costly also, depends what they want to do, replace, repair or second hand.
