Brake master cylinder
Has anyone changed 1 before
Is it a mare or just straight forward.
The only reason why am asking is cos the pedal creeps to the floor when foots pressed on it sitting stationary with the engine running.
No leaks NOT that a can find
They are fairly fiddly due to the car being primarily designed as left hand drive where it's a lot simpler.
Bleeding the brakes can be the hardest part, will probably need VCDS to run through an ABS bleed cycle.
