17" 7.5J ET40 wheels on a MK1 fabia vRS
As the title says really, ive used a wheel calculator and it says the wheel will sit 11.4mm into the arch and 1.4mm further out.
That won't cause any rubbing on the strut etc will it? I'm away from my car this weekend so I'm unable to check.
Cheers guys.
Are you using the spiders with spacers?
Did you take the spacer into account as you may also have the issue of them not clearing your brakes
No the spiders fit over the taroxs fine without spacers. In fact there's a bit of gap between them and the inside of the spokes.
I'm running 17" 8.25j.. you'll be fine
I have 17" with 215/45/17 anybody have fited
