Indicator stalk removal
Hi, I'm looking to replace my indicator stalk, does anyone know of a tutorial to show me how I replace it pls?
Basically is goes -
Airbag off
Steering wheel off
Column shrouds off
Steering control unit drop down
Steering sensor out
Contact ring off
Stalk out
Then the reverse to install
  • 5 weeks later...
easy enough job, though disconnect the battery first then press the brake pedal to lose any power left or the airbag may go off.
Screwdriver for removal of airbag but as above took about 30 mins, make sure you line up the steering wheel before you take it off!
