Skoda 1.6 dsg gearbox
Hi,
Sometimes when put into drive, the dsg gearbox acts like it is still in neutral.
Got a local garage, who I trust(not Skoda dealer) to check the fault codes on it and it only comes up with fault code:
06012 (24, f1, 17,7c)
Please refer to relevant technical manual.
Tried finding fault code online without any success.
Anyone got any ideas, what it could be and/or fault code links:
Thanks sorry IDanl,
sorry for late reply. Went to Bristol and got a new clutch put in but now 4 weeks later playing up again, this time moves of then acts like it is in neutral. This only happens after standing still parked for a while, not whilst I am driving. Going to get diagnostics done again to see what codes will come up this time.
Not sure what you mean by relearn.
Clicked your link: http://wiki.ross-tech.com/wiki/index.php/7-Speed_Direct_Shift_Gearbox_(DSG/0AM)
and it says,
This should be obvious but the procedures on this page do NOT apply to transmissions other than 0AM. For example, longitudinal 7 speed DSG's like the 0B5 used in the B8 S4 use a different procedure.
Mine is a 7 speed DSG's.
I do not know if you have heard of them but I took it to
http://www.bristolgearboxcentre.com/#!dsg-7-speed-dry-clutch/x6c6q
who seem very professional.
Thanks again
Oh and one other thing, no faults are coming up on diagnostics, strange!
That link is for the 7 speed dryclutch DSG gearbox. I have the same engine and gearbox in my Octavia, and had my K2 clutch replaced under warranty by Skoda due to juddering.
Edited by Hollinshead
and it says,
Thanks again
That's the right link for your gearbox. The 7 speed longitudinal gearbox it's referring to is a completely different box and is a 7 speed "wet" clutch gearbox with a much higher torque limit.
ok thanks,
