Fabia 16V and 205/40 17
Do 205/40 17 tires fit fabia 1.4 74kw model? The car isn`t lowered..
The seem to fit perfectly in fabia rs, but what about in my case?
What ET would you recommend for these rims? 35?
Does it make any difference that the rims are 7,0Jx17 or 7,5Jx17
Thank you :thumbup:
All the Fabias in the range are the same except for the different engines. If the 205/40 17s will fit the vRS they will definitely fit your car.
Thanks a lot.. i just needed to ask to be sure.
Ill say though if you're gonna fit 17s, our gonna wanna lower your car as far as looks and handling is concerned.
I`ve been thinking about it, but there are two problems at the moment, money (this can be solved) and warrenty..
The warrenty (of the cars bottom "dont remember the right english word for this :) " is void at the moment when the lowering spring are installed..
True, unless your dealer is wiser than the average beurocrat and will allow for you to have your springs from a renowned manufacturer like H&R without voiding warranty.
