Steering Angle Sensor
is this the right part for the Steering Angle Sensor on a Skoda Octavia II year 54 1.9 tdi iam getting the orange wheel on dash lad stuck it on his computer and came back saying it was this part and steering seems to pull to the right a bit
i doubt this would go faulty, there probably is an issue elsewhere
if you are sure you need one, i think i have a spare one in my box of bits
just going of what lad say he ran that  VAG and came up with  Steering Angle Sensor says you have to take steering wheel off to fix it so don't no if this is right,,like I said before my steering is off set abit when driving and has that  orange light on that looks like a steering wheel
the fault code might say steering angle sensor
what is the fault code
speed sensors, abs fault can cause issues
don't no the code but I all so have speed sensors, abs fault but lad said it was sensors that fit in the wheels,so I need four of them doing to and the steering angle sensor to
Have u tried calibration of angle sensor? If i recall make sure steering straight ahead full lock one way and hold 10 seconds full lock oposit way hold 10 seconds back to stright ahead and hold 10 seconds.
just tried calibration it like you said still offset I little bit with  orange light on still
any idea dudes then,,is it hard to change the steering angle sensor
I'm in Scarborough tomorrow if you want to pop over
cheers eddie if I was going over that way I would of popped in cheers for offer :clap:
