MAF Sensor output signal voltage.
In the never ending search for why my Octavia is down on power, and running super rough, I am back round to the MAF sensor. This is despite the fact that it is new, but because so much else has either been replaced or checked and because it is not a genuine VAG Bosch part (Replaced by garage and no Bosch branding on it).
Checked out the 12v, ground and 5v to the MAF sensor and all is well.
Onto the output signal:
With key in run position but engine off and MAF sensor plugged in:  output voltage =1v
With engine idling and MAF sensor plugged in:                                 output voltage =1.6v
I have the horrible feeling that this is OK but can't find figures to check against, any chance that it is a bad MAF sensor?
Any other checks I should do?
Car: Octavia 2 1.9 PD BXE
Edited by Octy0GG
Took more complete MAF Sensor output readings today.
Key in off position:                                      Output      0v
Key at run position, engine not turning:      Output     1.04v
At idle:                                                        Output      1.60v
1500 RPM:                                                  Output     1.95v
2000 RPM:                                                 Output      2.31v
2500 RPM:                                                 Output      2.70v
It would be glorious if someone could tell me that these figures show a faulty MAF sensor. I live in hope but have the horrible feeling that they are OK.
Edited by Octy0GG
