Fuses
This may have been posted about before I dunno ? :ne_nau:
Whilst doing a phone install on my wife's Fabia I managed to short out the interior lights with a screwdriver ( fitting the mic inside the courtesy light) so I dug out the owners manual to trace the location of the courtesy light fuse.
Now as far as I can see the owners manual although giving the numbers for each fuse (page 135 in my manual) it does not have a fuse panel layout ?
The fuses appear not to be numbered on the panel making the task of tracking down individual fuses a nightmare ! :banghead:
Luckily, I remembered that Stuart had the fuse panel layout on his site http://www.fabia-vrs.com/fusepanel.htm which I located and printed off & which is now tucked inside my owners manual ... well worth doing, thanks Stuart ! :thumbup:
good idea, must do that myself... stick it to inside of fusebox cover :thumbup:
It does, on page 136. But some of the numbers are hard to read I'll agree.
Yeah, sorry you're absolutely correct I should have said page 136 of the manual in my original post.:o
The point I was making though is that although it does give you a fuse number it's not clear (to me anyway) where that fuse is then located on the panel. :confused:
By printing out the layout from Stuart's site it's then easy to locate & replace the correct fuse. :)
Note to myself: must remember to buy some spare fuses when next at the stealers ! :D
