skoda Octavia II 2006 1.9 tdi
Hi can anyone tell me what the tool is that i need to remove the two nuts holding the back brake caliper holders on  as i want to renew my discs it looks like a spline but the the ones i have wont fit i have torx ones but feel a bit loose any help would be gratefull
cheers :sweat:
Don't quote me but isn't it a T30 torx. I have a long one on a half inch drive socket. Can get from eBay and Halfords if really stuck.
Hi thanks for reply have a set of t torx including the 30 but just dont seem to fit right and dont want to damage the splines by not useing the right gear
It's not torx, it's a triple square or XZN bolt, M14 IIRC.
Sent from my D5803 using Tapatalk
Thanks for your reply now i know where i am going sort of knew torx didnt fit right
cheers :clap:
Hi did they work out strong enough as ive been told these are really tight ?
Yes, they were strong enough.
My issue was that I couldn't get the car high enough off the ground to be able to get enough leverage on the breaker bar.
Ps don't the disks come off without the calliper carriers being removed. If they are lose on the hub they will come away. Did this on my octavia and also the rears on a Golf Mark5.
On models with the smaller discs you can usually remove and replace the discs without removing the carriers.
On a 2006 unless it's a DSG then you should be OK.
Soon to be doing mine and mi e are the smaller ones so hoping it makes it a little easier.
