Kodiaq steering wheel vibration
Is anyone experiencing steering wheel vibration while driving between 100–130 km/h? The issue occurs on both the 20-inch summer wheels and the 17-inch winter wheels. The 20-inch wheels have been checked for balancing and everything is fine.
On SKODA service says that its normal for vibration 🤦 for my point it cannot be normaln that steering wheel is shaking on 2 different wheels. I hope that i am not only one, because they said that they checked suspension and all is OK, but i also see that od higway car is getting pulled always to the right.
Car is Kodiaq 1.5 TSI mHEV DSG 2025
I have noticed the same issue in a 2025 model 2.0 TDI 4x4, 19" Tyres.
The steering wheel vibrates at 100-120 km/h. Car has only 5k km so far. Strange vibration that should be coming from the tyres. Have not checked mine for Rebalancing yet.
I also feel a very light vibration on the pedals when accelerating and breaking as if the tyre vibrations are transferred to the floor and pedals of the car.
Maybe due to the type of asphalt i drive on.
  • 4 weeks later...
Did you fix issue with steering wheel?
No I have not. I think the tyres need a bit of balancing but have not done that yet.
I've done a few motorway miles on mine at 70mph and a quick blast at 120mph on a disused (but safe) runway, no issues at all and felt very solid at speed. In the past I've noticed uneven tyre wear, tracking after hitting a pothole (the UK roads are really bad) and poor balancing to be the cause. Sometimes balancing weights can fly off if not attached properly. Hopefully a friendly tyre centre can take a look for you.
I have done three time balancing wheels and it not fix issue..
In the UK, we have the AA and RAC motoring organisations that can witness your problem and submit evidence to Skoda/dealer. The AA has helped me reject poor cars in the past.
There's also tracking/camber alignment to check. Have you test driven an identical car with a Skoda representative in the car with you?
Edited by BabyDog
Crap POCO X7 Pro Phone ;-(
  • 1 year later...
Did you slove this problem? I have exactly the same issue. Tires were balanced with Hunter Road force 3 times, winter tires exactly the same problem.
Well not yet. I finally manage with another skoda service where we start to work on something.
They saw on car that it really shaking and we managed to replace on warranty wheel bearings, but this not solved issue, so they have now car on service again where they are searcing again for issue.
Please let me know if you solve it. I changed dcc on warranty and that not helped. I also change both front arms, dual mass, silent block DSG - nothing helped
Wheel my car is still not fixed yet :(
They first replaced wheel bearings but there was no difference. Now they replaced suspension bushes but i think now its even worse. I will get in contact tomorrow to see futher steps. They also checked the wheel alignment/centering again but there is no deviation. I am getting crazy with car..
I know that feeling, i was on chassis vibration table and they found that one wheel bearing is bad and one ball joint too. But I don’t think it will help - if not I will buy 17’ wheels. It could be resonance of the system and there is no solution for that. Or steering rack
I have winter 17' wheels. Its same on them, so there is no difference on wheel type.
Hmmm… Did you try Hunter Road force?
On wheels 20' yes and there was no deviation. All okay with tyrees and wheels.
Yeah ok, i think that it could be steering or some electronically issue. I will let you know after change of wheel bearing and ball joint. Btw - bad ball joint was detected only when car was bouncing- no visible movement, detected only by alligator clips.
Do you have any new information?
Waiting for your feedback if any better on your side after changes.
I am waiting if they will come to something new what it could be wrong.
Well after my both front shock absorbers changed, vibration is much less. Ball joint and bearing will change 21.10.
For example mine vibration.. after all changes i now came from most 109km/h to 127km/h shaking i came to shaking from 100 to 142km/h..
We have changed:
wheel bearings --> little less shaking
control arm bushings / suspension arm bushing --> more shaking again
Its hard to record to have best video
Yeah that’s exactly the same What i got. I forgot, I also change both top strut mount (at my expense). One car reporter also told me that it could be just resonance of the system and suggest to drive 150km/h
Hello guys, is the problem witaj vibrations solved?
I havevthe same problem with my new skoda. Skoda warianty servicd said that it is normal. I couldnt find solution on polish forums. That the reason i’m here
Whats your production date? I have much less vibrations after both dcc and top strut mounts change. But my car still feels more pathholes than normal i think - it could be ball joint that will be changed
Mine is january 2025.
I am waiting for next week inspection.
Mine 05/2025
Recently Browsing 1
