Rupes Sanding Discs.
Anyone here used these?
Used them last night on one of my headlights as it's starting to fade. Did a nice job but didn't remove some of the marks.
Never really had to wet sand before so I'm guessing that means I need to use more abrasive paper? Went from 2000 to 3000 last night. Or could I just do more passes?
There is a small patch where it is still very slightly rough and has what I can describe as spidering on there.
Are they reusable?
Thanks!
Sent from my SM-N910F using Tapatalk
Sorry Ben - no experience of these..... but following with interest...
You need to start with 600 then 1000 1500 2000 3000 . Make sure the hole of the light is opake. Then 2 coats of lacquer or sealant of your choice, amazing results can be had.
You dont need to rub to hard just getting a uniform finnish.
