Footwell light loom
Can anyone tell me if the wire loom will be fitted for the footwell lights even tho no lights are fitted on my facelift vrs est ?
No light = No loom
I made the loom when I added them to my Vrs
If you need a loom send me a PM
Is it easy to install eddie as i hate messing with electrics ?
You will have to cut out some plastic on the drivers side trim and glovebox
For the wiring it requires one terminal to be inserted into the BCM plug and a ground
Then you need to code it with vcds
Leave it with me. Thanks for info.
