Bluetooth/ vcds
Does anyone know what modules need to be changed to completely shut off a factory Bluetooth unit so as far as the cars concerned it doesn't have one!?
You'll need VCDS to achieve this. If you're familiar with it, or have it yourself, do the following;
Goto CAN Gateway – Controller 19
Re-coding should be carried out using the Long Coding Helper. Select Byte 3 and put a tick in Bit 7 to enable Controller 77 Telephone. Write the Long Code back to the car.
You can also enable/disable via the Gateway Installation list, which achieves the same coding change as the steps above.
