Internal External temperature sensor
The temperature on my minidisplay reads -35c and the aircondition display reads -35c aswell, any clues?
I doubt both sensors broke at the same time.. , sometimes they do read correctly, I was gonna check the cables but it gotta be some sort of connection between the two sensors that is faulty since they are reading identical numbers for some reason?
I have the following error codes on the Climatronic:
0318 Air Conditioner Pressure Switch 0x23
030B Outside Temperature Sensor – Front Bumper 0x1d, 0x1e
04FA Recirculation Flap Servo Motor 0x25
I'm assuming these are the correct translation of the codes according to:
http://pics.tdiclub.com/data/517/Climatronic_Self_Diagnostics.pdf
Edited by MarkusDaMan
Sounds like your outside temp sensor is faulty. It's behind the right hand bumper grill as you look at the front of the car.
