Replace Columbus with Skoda sound system?!
On 12/12/2016 at 20:07, mspider65 said:
Hi, i had the same problem with my Skoda Superb 2012 with 10 channel  DSP Sound System but i found a very easy way to solve the problem.
1) disconnect the old Head Unit (in my case was an OEM Bolero unit)
2) disconnect the battery for at least 20 minutes (just the minus pole is enough)
3) connect the new aftermarket Head Unit
4) connect the battery
After this the amplifier goes in a special mode were is activated by the key-on can-bus message and deactivated by the key-off can-bus message and doesn’t need the activation message sent by the original head unit.
I have tested this on my Skoda Superb 2012 with 12 channel DSP Sound System and it works!
Max
This really solved my problem, I had ordered a Chinese Android Head Unit with Raise Canbus, all the Canbus functions were working except Car audio as the amp was not powering on, tried many options including adding another Canbus just to turn the amp on it still didn't work but this solution helped me after my struggle of 4 days.
Thanks Max (mspider65)
I have a Skoda Laura L&K (Octavia MK2 facelift)
To "EVERYBODY" - I have the same Problem - no sound at all after change "Bolero" with "Erisin ES8028V". After I do all the things that " @mspider65 " (Thanks a Lot!) suggest, the sound starts but there is some kind of very annoyng lateral noise when any kind of sound is played and now I do not know how fix this Problem 😞 Is there any solution for this?
