p0651 code
Hi has anyone had to deal with this code. It is
P0651 - Sensor Reference Voltage 'B' Circuit/Open
 Car starts but goes into limp mode.
Have swapped out ecu and still get same code
Have checked wiring and no obvious damage
Any help gratefully received
Yeti 4x4 2.0 diesel 110
thanks
bit of a google comes to this
http://www.vwt4forum.co.uk/showpost.php?s=4241897e828dd419e9eaed2bd34af15e&p=3416337&postcount=10
icon1.gifRe: Glow plug light started flashing then limp mode
The sensors have the same power feed, and the corroded wires inside the EGR valve can cause a short circuit that messes up the signal of other sensors.
If you unplug the EGR valve and erase the faults only the EGR related faults should come back.
seems a simple check that would start to rule things out or confirm something
Thanks bluecar1, tried disconnecting EGR but just got a second code
Finally sussed the problem.
Nothing to do with EGR
Throttle body sensor
disconected it and I can now drive as reving normally
Just waiting for new part
throttle body was the other thing that can up in the search
good to see you have it sorted
