Help and advice needed to fit 18"
Does anyone know if land rover mondails fit on a fabia vrs mk1 ??
Wheels spec
18x8j
Et57
Also will be fitting adapters
20mm
18s usually look massive on a mk1 Fabia.
With the PCs adapters it will make it et37 so should fit ok.
Would need 205/35/18 tyres
I saw a Fabia the other day with 18" wheels on.  It was parked up in Sainsburys so I went over to have a closer look.  I think he must have been on standard suspension as it looked like a kid's toy and was riding way too high.  The same goes for when they are on 17" Spiders for example, but this really did look a bit daft.
If the car is lowered on 17s then I think this is the best compromise as the standard 16" wheels do look a tad small.
There's an old thread with a couple of examples of how it might look,
http://www.briskoda.net/forums/topic/284290-whats-the-best-size-wheel-for-the-vrs/
Edited by skinnyman
205 will be stretched, also 205 30 18 would keep the Speedo correct.
35 would throw it out a few MPH.
Sent from my LG-D722 using Tapatalk
