External temp
As title really, my external temp display is out by about 5-7 degrees at least all of the time when compared to other cars anybody know if this could just be the sensor or something more complicated?
Sounds like a faulty outside temp sensor.
Try this. I found it on search when mine was faulty
Have you plugged VCDS into it as it might show why? I also pulled this from a workshop manual.
Testing ambient temperature sensor -Gl7-
Special tools, testers and aids required
- Hand-held multi-meter, e.g. V.A.G 1526 A
- Remove left ventilation grille.
- Take out ambient temperature sensor.
- Separate connector of ambient temperature sensor.
- Connect handheld multi-meter to the contacts of the ambient temperature sensor for resistance measurement.
Specifications:
Temperature Specification
-30⁰ C
Approx. 18265Ω
0⁰ C
Approx. 3300 Ω
20⁰ C
Approx. 1184 Ω
50⁰ C
Approx. 359 Ω
- lf that specification is not achieved, replace the ambient temperature sensor.
- lf the specification is achieved, then test the cable to the ambient temperature sensor.
- lf the specification for the resistance and the cable to the sensor are correct, then replace the dash panel insert.
Hope that helps in some way?
