Camber adjustment
Goooooooooooooood Morniiiiiiiing Briskoda users.
Todays question is regarding the camber on my Fabia. When I purchased it the inside wall of the tyre was going bald. Rotated the wheels and the same thing is happening to the new tyre.
I just purchased 16's from DanHaper on here and would like to see them last more than a week without starting to go bald. Any advice on fixing/cost?
Can't adjust camber only toe.
Assuming front, how are the console bushes? Alignment done?
From what I know about the car the suspension was recently done so I'd imagine that area is all good. I will be getting the wheels hopefully swapped over today so can get it checked. The alignment definitely hasn't been done as I can let the steering wheel go and the car drifts to the left.
I stand corrected :)
Edited by Steven2016
You can balance camber by shifting the subframe.
So potentially this could be expensive?
Get the tracking checked/sorted first. It sounds like it's probably out if your car is pulling to one side.
Tracking was done, it was +12...did hit a big pothole and although the car seemed ok once I got the alloy back on it tonight it pulled again. Getting it up on Monday to have it looked at.
