Gearbox failing is it worth the fix.
1st is fine 2nd whines 3rd OK 4th crunchy 5th OK 6th wooly and crunchy. Would it be worth reconditioning the gearbox 112k miles 1 year old smf and high friction plates. It's either recon it or engine swap for a mad petrol engine and rw/4w conversion lol
Have you changed the gear box oil ever?
It might be enough to quieten things down.
I did approx 150k on mine with no issues once the initial DMF issues were sorted out.
Haven't got a clue how to.vet in there.... it was changed last year when converted to smf but I was told it's sealed for life. The leak tells a different story. I have a look and throw a few litres at it
Was the gearbox fine before SMF change?
I think so was a year ago now. Had play in a bearing apparently bmwas advised it's OK not urgent and now it is :-( found a vrs engine and box off an 08 is it same as the 07?
Thought they might of used non vag gear oil but it sounds like it had issues before.
