Which Pagid brake size do I need? Please help
Hi all
Can someone be so kind to point me to which brake disc I need to select on the euro car part site. It's a FL 2011 plate VRS tdi and quite a number of options come up.
I want to take advantage of the 30% off before it expires as my discs are now due so thinking of doing discs and pads as a job lot.
Sorry if sounds thick but don't want to order the wrong one.
Thanks.
^Sorry, front brakes should have said I know
Changed mine recently to Pagid all round on my VRS 170 CR. I think the fronts were 312mm.
Is it not easier to take off a front wheel and measure the disc?
You would then be sure of ordering the correct one.
All octy VRS are 312mm discs on the front.
Thanks for the replies guys. Ok, so for the pagid front brake discs I'm assuming these are the correct pads?
http://www.eurocarparts.com/ecp/c/Skoda_Octavia_2.0_2012/p/car-parts/brakes/brake-friction/brake-pad/?101441139&1&241db42585cf7cd883d1bde530923d3304400412&000036
Also, in service book I have a PR code of 1KT so I'm assuming this refers to the 'rear' discs and are sized 272mm and then the pads to match the size of disc respectively. Have I got this right before I hit the order button?
Not sure about the pads. I think the rear disks were 272mm though.
Cheers. Erm, I suppose I could order the rear pads that state the size 272mm as I have cross checked the PR code in my service book against the disc on ECP. I'm sure they could just swap if found to be wrong.
I'd really like to get all 4 done now as I was originally going to do just the fronts but feel a full change would be best. What do you reckon?
