2.0 Tfsi oil Sensor Fault
I have the following issue fault
P0196 showing Engine Oil Temp Sensor (G8) Implausible Signal
So replaced the sensor cleared fault and is know back on.... Any more ideas on this how to solve??
Thanks in advance
Did you replace or reuse the engine oil?
Iirc you have the original dash type in there? You haven't retro fitted a different dash cluster?
Yes did a full oils and filter change at same time that was after most the used oil ended up on the drive ooooppppssss
I've had a retro fit maxi dot fitted 2 weeks back.... What is Lirc?
Lirc is actually Iirc which stands for "If I recall correctly"
Ah ok, thank you :) I did have the origanal dash but still had same issue before swapped.
If the sensor in the sump has changed, the dash cluster has changed (which didn't sort the issue) it must be a wiring issue. I take it the fault hasn't always been there?
When I got the car the fault was not there. You never mentioned it when you fitted the Can upgrade and cleared errors. Wirring looked OK but maybe I need to check abit closer??
So I have checked over wiring with still no joy still same issue grrrrr
