2012 Estate vRS CR- What costs/issues to expect after 5 years?
Morning,
I am about to service my 2012 Estate vRS TDI (60k miles), it will be its 3rd service.
I am trying to decide whether I should sell it before the next service around (75/80k), which would require the cambelt too or whether to keep it for the long run....
Except the cambelt every 5 years, is there anything else costly to be expected or do they tend to be reliable as long as serviced on time?
What realistic mileage can I expect out of it?
C.
I have the same car as you, but with 110K on the clock.
The only exta things I had replaced up to now are
The front disk & pads @ 80K
Aircon compressor at 105K
& DSG oil every 40K.
I expect to keep mines for a few years yet, as it is still very reliable
and a cambelt / waterpump every 5 years isn't too bad - compare to some other makes
Mileage wise, as skodas are used as taxis, the sky could be the limit
I'm on 125k
Only part's i have changed is purely maintenance.
Front Shocks
Rear bumpstops
Rear caliper/common issue.
Rear caliper backplates/common issue
Brakes disc and pads.
Engine still going strong cr170 with stage 2.
Original clutch and dmf so i believe.Will be getting done next year as it served well.
I have seen ex-police with 160k+ good engine i believe...
EGR valve seems to be quite a common and expensive bill but there are many that have done many miles and had no issues
Mine is a 2011 goes well has been superb mechanically - it's just approaching 60k now
Maintenance wise I just had the 60k service carried out to include fuel filter and a brake fluid change (changed the air and cabin filters myself with Bosch filters for £16 - took 5 minutes for each one). I had my cambelt and water pump done early (Dec 2015) to keep my mind at ease.
So it's had a couple of major services done, but now hoping to just add diesel and pay for minor Variable servicing until 100k!
Mine is a 2010 sitting at 117k at the moment. I do nearly 20k a year. Since the beginning of the year it has had
Exhaust gas pressure sensor £280 at indy
Variable service and dsg oil change at dealer £380
Rear wheel heat shields £150 at indy
Camshaft position sensor at dealer £550 took 8 days
Currently in the dealer for replacement turbo pressure actuator approx £450. Has been in for 9 days so far.
I got the cambelt and water pump done last year and was £280 at indy
Had been reliable until just under 6 years old.
Will probably keep it for at least another 6 months
OUCH!!
thanks everybody for the feedback, it is very useful.
Looks like the majority are very happy and low maintenance.
Thanks. That's exactly the scenario that concerns me :(
Does anyone have any other feedabck
Don't let that put you off...great motor.
