Rear Left ABS Speed Sensor
Three times now, my ABS, TC, and TPMS lights have come on.  Straight away I guessed an ABS sensor, and my VCDS scan appears to confirm it:
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
 Part No SW: 1Z0 907 115 G
1 Fault Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
 U1017 - 007 - - Intermittent
 Freeze Frame:
 Fault Status: 00100111
 Fault Priority: 0
 Fault Frequency: 3
 Reset counter: 255
 Mileage: 118294 km
 Time Indication: 0
 Date: 2014.14.21
 Time: 11:23:44
Freeze Frame:
 RPM: 2367 /min
 Load: 11.4 %
 Speed: 47.0 km/h
 Temperature: 72.0°C
 Temperature: 23.0°C
 Absolute Pres.: 1000.0 mbar
 Voltage: 13.843 V
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
 Part No SW: 1K0 907 379 AN
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
 003 - Mechanical Failure - Intermittent
 Freeze Frame:
 Fault Status: 00100011
 Fault Priority: 1
 Fault Frequency: 3
 Reset counter: 105
 Mileage: 118260 km
 Time Indication: 0
 Date: 2014.14.20
 Time: 07:32:02
Freeze Frame:
 Count: 0
 Count: 0
 Count: 4608
 Count: 77
 Count: 49458
 Count: 781
 Count: 0
 Count: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
 Part No: 1K0 909 144 H
1 Fault Found:
01316 - ABS Control Module
 013 - Check DTC Memory - Intermittent
 Freeze Frame:
 Fault Status: 00101101
 Fault Priority: 3
 Fault Frequency: 3
 Reset counter: 105
 Mileage: 118294 km
 Time Indication: 0
 Date: 2014.14.21
 Time: 11:23:42
 Freeze Frame:
 Voltage: 13.88 V
 DU
 Temperature: 21.0°C
 RPM: 2394 /min
 Speed: 48.0 km/h
 Speed: 48.0 km/h
 Count: 0
Can anyone confirm for me that this is indeed the case, and is 1K0927807 the correct replacement part number?
Thanks!
It may be the ring in the hub and not the sensor.
Edited by trundlenut
Is that something I can check myself by removing the wheel?
Just a thought; I recently had the rear discs and pads changed. Could it be that the sensor isn't securely fastened?  Where are they so I may check them?
Edited by planehazza
The sensor pokes through the hub and is held by a small fastener, its unlikely that it has come loose as the hole can be quite tight once they get a bit of corrosion.
I have only ever had rear ABS sensors fail due to the wheel bearing being worn and it ends up rubbing away at the end
The sensor fits into the back of the hub. Follow the wire, on the rear there will only be one.
Mechanical malfunction is the clue. It's not electrical so more than likely the bearing.
New hubs required as the abs speed sensor ring will be corroded. Not a pleasant bill and a bit of a design fault.
Cost me £300 for both rears on my mk5 golf.
As per post#7 I am afraid, my VRS Pre-FL hub/sensor failed after 7 years with the same indications amd it cost a fair amount at the dealers which Warranty Direct refused to cover even the agreed percentage due to corrosion vice a simple ABS sensor failure. They eventually paid £220 but by then they'd lost my custom. If you can source parts and are handy with spanners etc then good luck.
The rear bearings on these cars are a piece of cake to fit but if you haven't got the tools already it would be cheaper to just pay for it doing
Getting the carrier bolts undone is an absolute pain without the car on a ramp and an impact gun.
Thanks all. I was planning on getting billsteins fitted and it would make sense to do all this.  Now I can't help but consider it may be better to sell the car on :/  There are a few niggles with it that I fear might cost in the long run...
I did mine on my vrs on the drive all you need is a trolley jack an m14 1/2inch spline bit £5 on ebay and a 3 foot breaker bar, I got my rear bearing from euros for £70 the hardest part was the caliper carrier bolts I cracked them with the breaker bar bit by bit and they came loose, I also used the breaker bar on the bearing bolt and it cracked it no problem all in took about an hour on the drive and cost £75 for the m14 spline tool and the bearing .
Also need a torque wrench for the 200 Nm plus 180 degrees for the hub bolt (depending on spec).
I don't have a torque wrench nor a breaker bar.  I'd rather just pay my mate to do it rather than me struggle around with rusty bolts and the wrong tools.
The fault appears to be constant now.  Binged on again this morning and hasn't gone off the dash this time.
Just had a quote back for £217 for sensor and bearing.  Will I need to replace the sensor? The quote for the bearing alone was £140.
Just bought a spline and torx set , a note inside said as some carrier bolts are glued in use a hairdryer to help soften the glue before trying to unscrew them.
Wonder if it helps with the Octavias
Swap the sensors between the rear wheels. If the fault moves to the other wheel it's the sensor, if not the ring
Cool, I'll try that this weekend.
Normally you won't get a mechanical fault with a sensor.
Thanks.  I'm not really confident with VCDS etc so when I read the logs I just assumed it was pointing to the sensor.
This morning, I started the car up, and ABS was on the dash on it's own right from the start, Had no choice but to drive it anyway and take it easy.  I'll have to check again tonight.  I'm probably ordering my B12s from ebay.de today so will hope to get it all fitted next week.
The sensors were fine on mine they didn't need replacing
