Lumbar Support Repair
Has anyone fitted one of these??
http://www.skodaparts.com/product/octavia-
lumbar-support-repair-kit-1996-2008-29554
If so how easy was it? Ordered one for mine and wondered if anyone had any tips!
Thanks in advance!
Apologies the original link didnt work!!
Seat out and dismantle the whole of the back. It is a fiddly complicated job. Plus you may have the seat airbag to contend with.
I did a how to for fixing the cable if it snaps.
On mine the cable was fine but the plastic part at the bottom has broken into pieces. I did find another identical seat (black Elegance) at a breakers but that had the same issue!! :(
Re the airbag issue, Im guessing that would be in a self contained unit inside the seat so shouldnt cause any concern especially if unplugged??
And the 'how to'guide in the Techincal Section is excellent ;)
Just make sure you disconnect the battery first. IIRC the airbag wiring is a bit fiddly through the seat too, but it's a long time since I had a mkI.
OK thanks for the advice will do! ;)
