Draining coolant - l need a diagram or pic pls of where the drain is
Hi,
I've read the old forums on draining coolant from 2002 octavia but don't understand where the drain is. Could someone pls show me with a picture or diagram. Sorry not good with mechanicy things! Thank you!
Looking from the front of the car it's on the bottom right hand corner of the radiator at the back.
However if you have a vrs, you'll need to remove the engine tray to get access to the drain tap. Probably non vrs Octavias have something similar.
