Gearbox gone
Well had driveshaft done had it for a day then car went again the gearbox gone on it trying to get one but what one can I put in it its 02 skoda vrs 1.8t engine code aun any advice needed asap like to get it sorted
If your car is a vrs, the engine code should be AUQ, and the gearbox should be an 02JP with an EHA  ratio code. If you have an AUM code, then the car has had an engine change at some point in it's past.
Hope it helps
Found a gearbox out of mk4 golf 1.8 t same except for the ratio code will it effect everything
What codes are they?, I'll check out the ratios for you.
I have look at the ratio on gearbox all good right next door from where I live vrs still lives happy days
stick in a 02m tdi box.....
the o2j is junk
Edited by grizzle245
