Wheel choice
I'm looking to put winter wheels on the 230. There's a set of 18inch bbs ch's local to me but theyou are ET45 whereas the et of the 230 is 51.
Does anyone know if it's ok to put a different ET on or do I need to stick with the 51's.
go to willtheyfit.com put all the info in wheels size et and tyres and it'll tell you everything you need to know
You'll be fine - the variance is minor and the lower the offset, the wider the track so there's no chance of them catching.
Assuming the other specs are okay - PCD is 5x112 and centre bore is 57.1, then they'll be all good.
Thanks for the replies guys
