ABS and EPS light and handbrake light.
late 2006  Fabia 1,9TDI
I aws driving for 10-15 minutes, after I parked with enging running for 30 seconds first the ABS and EPS light came on.. after 10 seconds the handbrake light start to flash and it was beeping, startaed to drive 20 meters to park the car on a better spot the lights went of and the beeping stopped, and they did not came back for the rest of the days 250km drive that day..
I will have access for vagcom to the weekend, but is it anyone of you that have hade similar problems / warning lights and what was the poblem?
Edited by Guest
The ABS and EPS (ESP?) are dependent on maintaining a certain level of voltage, so maybe your alternator is disengaging when the engine is idling?
Maybe, what voltage shoud a multimeter show if it's OK?
I'd expect 14.4v, but I also think your fault is intermittent.
Alternator load signal wire possibly. Does your battery light come on when ignition is on but engine not? If not then chances are it's this. Should be some details if you search here
