exhaust noise
hey guys,
My Superb has a exhaust noise which annoys me at idle and when it reaches 1500rpm in acceleration. it sounds like a RONNNCCCC, I thought it was the heat protection but mechanic said it was this part:
893635243_o.jpg?nc=636144326386597754
can anyone confirm it please? it's easy to fix (beside the cut and weld) ?
cheers!!
Best way maybe sometimes cheaper is to buy the actual exhaust piece and fit it on your self i know my local place said fitting and welding a flex joint they asking £65 and im sure i can get the exhaust piece for maybe £50 max id rather have a the full pipe with warrenty and looking nice then a welding flex joint with a risk of leaks and rust
Hello.
I have almost the same problem (it's not the noise, but the fume that escapes), and I would like to replace the pipe, just as you say - I'd rather have the entire pipe. However, I am having trouble finding one that fits properly. Does anyone know where I can find a perfect fit for a Superb from 2006, 1.9 TDI AWX engine?
Thank you.
