Air bag warning lights
Had to remove glove box on my 07 Octavia estate & leave it out for about a week,unplugged the passenger airbag switch to fully remove glove box."Air bag off" light then on on lower console & air bag light on on dash.After refitting lower light went out straight away but dash light goes out but comes back on again.any thoughts?
That's normal :)
When you unplug any part of the airbag system, including the airbag off switch it'll log a fault code causing the airbag light to stay on.
The only solution is to have the system reset, a dealer will probably charge you but if you can find a local member with VCDS they can do it in a couple of minutes.
Many thanks
What if I disconnect the battery for 30 mins?
OK,thanks,was worth a shot!!!
