Help needed-Position of Rain sensing relay on an Elegance
Anyone know where i can find the rain sensing relay on a '57' Octavia elegance. A garage recently took out my cluster pack and i suspect they may have knocked this relay, or something when moving the Cluster, assuming that is it is under the dash somewhere, only When i switched the intermittent wipers on last night i got 1 sweep then nothing so i'm hoping it is just the sensor.
Wont be going back to that Garage as they appear also to have put the wrong gear box oil in my car as well as they only charged me £14 for replacement gearbox oi, this sounds way to cheap for me so ordered 3L of the Vag (A2) ending stuff and will get another garage to add that for me..
The RLS (rain line sensor) is fitted on the windscreen where the rear view mirror mounts. There isn't a relay anywhere...
Ideally, you need to get a scan done using VCDS.
Thanks for the answer, just seems strange timing for the Sensor to possibly go, but i will get it looked into thx
