Which Bluetooth Module?
I am looking at getting a Bluetooth module and wiring harness but there seems to be many different part numbers available. To prevent buying and fittting one that isn't compatible, which will work with my setup?
I have a Bolero, MFSW, Maxidot and an iPhone 6S.
Any suggestions other than eBay for a reasonably priced one?
Thanks.
Edited by Metblackrat
Do you have an FL model? If so you are not really constrained much at all given you have maxidot. I would get a 3c8 035 730 d or above module. It will allow a separate media player to connect as well as a phone and works in hfp mode with iPhones and premium mode (allowing text readout and wifi hotspot) with Samsungs.
The alternative hfp only modules are not much cheaper anyway and if eBay is not your preferred route, www.car systems.pl is as good a place as anywhere. They will supply loom and mic with the module if needed.
Adam
Edited by adamal
