I need serious help after fitting projector headlamps
Hello!
I have a Fabia 2009 preface, born with H4 headlamps. Tonight i fitted projector headlamps(One h7 and a shutter to high Beam).
My low Beam Works fine, and if i pull the stalk backwards the high Beam(shutter) Works.
BUT when i Push it forward so i Dont have to hold it for high Beam, the shutter opens and the bulb goes Out :(. How do i Fix this?.
Best regards. - kim
You might need a different wiring loom for h7/projector setup compared to h4 or perhaps you simply need to recode the appropriate control unit in your car.
Sounds like the bulb feed is still set for h4 operation (stalk in flash position powers both dip and main filaments - stalk in main position switches off dip and turns on main). The single h7 setup requires constant power in both dip and main positions.
But how do i do it?. Im going to Run xenon and was hoping i could do something there. :)
