PF Octavia coding help please
Hi
I have decided to upgrade my octavia in a comfort sense - i.e. cruise control, hid, and single click unlock on all doors.
The car is a pre facelift 2005 model (mk2) and had a blown headlamp.  I purchased the londonhid kit as recommended (4300k 35w non canbus) but after installing, the bulb warning light went out!
i thought id code it anyway, but am unable to find the setting of bixenon shutter anywhere.  can someone pls help.
also, which model controller do i need for cruise control, and where can i select the 1 click unlock on the remote pls.
​Kaz
Edited by sebring
hi mike
thanks for your help with this.
I have coded the following:
byte 3 bit 4 does not exisit (blank)
byte 2 bit 2 - unticked cold lamp diagnosis
by19bt0 - cold diag low beam - (unticked)
when using headlight flash - the hid's flicker / turn off
please also find attached the full scan as requested:
Saturday,03,December,2016,19:52:19:30835
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: TMBCS21Z962126872   License Plate: OCTAVIA
Mileage: 218700km-135893mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBCS21Z962126872   Mileage: 218700km/135893miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 BE    HW: 028 101 194 7
   Component: R4 1,9L EDC 0000AG  7000
   Revision: 12345678    Serial number: SKZ7Z0E3045347
   Coding: 0000078
   Shop #: WSC 73430 790 00000
   VCID: 67DD4D755615A726359-8032
2 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 1050 /min
                    Torque: 114.0 Nm
                    Speed: 0.0 km/h
                    Load: 12.2 %
                    Voltage: 14.21 V
                    Bin. Bits: 11000000
                    Temperature: 17.1°C
                    Bin. Bits: 10110000
16567 - Fuel Temp. Sensor A (G81)
            P0183 - 000 - Open or Short to Plus
             Freeze Frame:
                    RPM: 1764 /min
                    Torque: 80.0 Nm
                    Speed: 34.0 km/h
                    Load: 27.1 %
                    Voltage: 14.36 V
                    Temperature: 13.5°C
                    Temperature: 88.2°C
                    Temperature: 61.2°C
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 042 H    HW: 02E 927 770 AD
   Component: GSG DSG         041 0910
   Revision: 04004010    Serial number: 00000503010028
   Coding: 0000020
   VCID: 183F3E892BEBD8DE4C3-804D
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8DB5156E05CFE6AD9-806A
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1Z0 820 047
   Component: Climatic PQ35   004 0201
   Shop #: WSC 00000 000 00000
   VCID: F0EFA629E3DBE09EE43-80A5
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000003137676
   Coding: 80880F030004140000110D000000000000087B075C
   Shop #: WSC 73430 790 12345
   VCID: 3979DB0D7021E1D693D-806C
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
3 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
            012 - Electrical Fault in Circuit - Intermittent
00979 - Lamp for Low Beam; Right (M31)
            010 - Open or Short to Plus
00978 - Lamp for Low Beam; Left (M29)
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: Q4 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0EG9YP
   Coding: 0020788
   VCID: 377DDD354635F7A6659-8062
   Subsystem 1 - Serial number: 6332MSME0A1D1F60H
   Subsystem 2 - Serial number: 6342MSME0A1705612
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0010012
   VCID: 76E3103101BF4EAEBEF-8023
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 910 D
   Component: KOMBIINSTRUMENT VD1 3562
   Coding: 0003401
   Shop #: WSC 24015 576 92309
   VCID: 3467EA3957431CBE40B-8061
1 Fault Found:
01314 - Engine Control Module
            004 - No Signal/Communication - Intermittent
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010552582FA
   Coding: 3F3F0340071303
   VCID: 2A5BF44185875A4EEA7-807F
2 Faults Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 63
                    Mileage: 185285 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:01:23
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 63
                    Mileage: 185285 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:01:26
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3562
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2346
   Coding: 0000756
   VCID: 3663D031413F0EAE7EF-8063
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 3365E925524D1B86591-8066
1 Fault Found:
00003 - Control Module
            005 - No or Incorrect Basic Setting / Adaptation
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01D002007F2D8505485F861004CC
   VCID: 79F91B0D30A121D6D3D-802C
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000756
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2405
   Coding: 0000144
   VCID: 326BEC21AD57128E527-8067
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
End   ---------------------------------------------------------------------
   Coding: 0010012
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Look for a 1K0 953 549 AG controller for CC
Any reason why you're using such an old version of vcds. If it's the obvious one, then a genuine cable and up to date software may be useful.
lcode 2 didn't have the options either I'm afraid.
I tried changing the bits manually but it said that I hadn't changed anything.
any other ideas?
I would happily buy the genuine cable but cant afford it at the moment.  If I could find someone who sold it so I could pay monthly, I would buy it!
 Are these also compatible:
1K0-953-549-AG Type 2 SW 0070 Highline Yes 1.3
1K0-953-549-AJ Type 2 SW 0070 Highline Yes 1.3
1K0-953-549-AK Type 2 SW 0070 Highline Yes 1.3
1K0-953-549-AL Type 2 SW 0070 Highline Yes 1.3
1K0-953-549-AQ Type 2 SW 0070 Highline Yes 1.3
1K0-953-549-AS Type 2 SW 0070 Highline Yes 1.3
Edited by sebring
Any thing else I can do to fix the lights??
There were no tick boxes - the area was blank I'm afrsid
hi all
I have tried this with my mechanics v16.8 and am still seeing the same options - there is no option for Byte 3 Bit 4 Xenon headlights without shutters.
LCODE2 displays exactly the same - there is no tickbox.
I tried changing the bit code manually, bit when I try to code it, it says nothing has been changed!  Any ideas to why its not working??  There is no error light on the dash - but when I switch on the main beam - the hid's flicker - and when I turn off the main beam, one or both of the hid's will go out, until I switch the lights off and on again!
