Bulb warning light on since unplugging head light switch
Since the other week when I unplugged the headlight switch and started the car my bulb warning lamp comes on when I start the car yet none of the bulbs are out all are working.. Any ideas?
Why did you have reason to unplug the headlight switch? Before moving on; do you mean in a MkI Octavia or a MkI Fabia?
Was changing the glow plug relay.. It's behind the headlight switch so had to unplug it to drop the lower dash panel down while it was unplugged I started the car..
And I've got a mk1 Fabia vrs
Might just need the fault code cleared. Happens all the time at work with car when we install meter wiring. Had a Prius in and we left some of the dash unplugged when we tested and it came up with all sorts of errors. Cleared the stored codes and was fine.
