VCDS printout,what does it mean?
Evening folks,
   I have been scouring the forum trying to get these niggling problems sorted,changed switch panel,CCM,window regulate control and locks.
 Anyway to cut a long story short,I contacted lwalker whose name appears on the VCDS owners and being the gentleman that he is,he agreed to run the program on my auld 02 Mk1.Thank you lwalker,you are a scholar and a gentleman. :thumbup: It was late and I had a bit to go so we couldn't work through it.
 So I'm uploading hoping someone will explain it to me and tell me what I have to change,replace,apart from "The Green Lady" herself.
Log-NOEL-TMBBP21U022572663-401330km-249374mi.txt
I had a bit of bother trying to get a copy and paste job done.Finally worked something out,no idea what :S But it's up,so hopefully someone will be able to give 's an idea what to do.All advice appreciated.
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 31480
   VCID: 70E5BB353046C7A19FB-513C
10 Faults Found:
01336 - Company Data Bus for Comfort System
            37-10 - Faulty - Intermittent
            49-10 - No Communications - Intermittent
01330 - Central Control Module for Central Convenience (J393)
00462 - Control Module for Seat Memory; Rear (J522)
            49-00 - No Communications
01304 - Radio
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
00463 - Control Module for Digital Sound Package (J525)
Address 17: Instruments        Labels: 1U0-920-xxx-17.lbl
   Part No: 1U0 920 911 F
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 23412
   Shop #: WSC 31480
   VCID: 3261713DFECAB5B1A9F-515A
   TMBBP21U022572663     SKZ7Z0A1081204
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 3Y Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 31480
   VCID: 36694D2D12A2A991857-4B18
   Subsystem 1 - Part No: Steuerger
   Component: t Fahr. antwortet nicht
   Subsystem 2 - Part No: Steuerger
   Component: t Beif. antwortet nicht
   Subsystem 3 - Part No: 1U0959811D
   Component: HL    antwortet nicht
   Subsystem 4 - Part No: Steuerger
   Component: t HR    antwortet nicht
6 Faults Found:
            37-00 - Faulty
01299 - Diagnostic Interface for Data Bus (J533)
5 Faults Found:
01304 - Radio
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1U0 035 161 D
   Component:  Radio GRO         0001
   Coding: 00407
   Shop #: WSC 31480
   VCID: 2A51695DD61AFD7111F-4B18
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
