Fuse 15
Read a lot about cluster problems and people saying take fuse 15 out it would help a lot if what is fuse 15 because mine is different from others and from where remembering there is a fuse box in the car and also under the bonnet
What is the issue you are suffering with? Is the dashboard cluster not working properly?
Check out this link...
http://www.briskoda.net/forums/topic/324958-octavia-mkii-dash-panel-fuse-details-2006-19pd-lk-estate/
_____________________
| 01 02 03 04 05 06 \
|____07 08 09 10 11 \
|____12 13 14 15 16 1718192021 |
| 22 23 24 25 26 27 28 29 30 31 |
| 32 33 34 35 36 37 38 39 /
| 40 41 42 43 44 45 /
| 46 47 48 49 /
______________
01: Diagnostic socket 10A
02: Control unit for ABS, ESP 5A
03: Airbag 5A
04: Heating, Air conditioning system, Reverse lights 5A
05: Control unit for headlamp beam adjustment 5A
06: Instrument cluster, Control unit for automatic gearbox, Control unit for electromechanical power steering 5A
07: Telephone preinstallation 5A
08: Towing device 5A
09: Not assigned
10: Not assigned
11: Parking aid 5A
12: Central locking control unit 10A
13: Diagnostic socket, Light switch, Brake light 10A
14: Control unit for automatic gearbox, Selector lever lock 5A
15: Central control unit -interior lights 7.5A
16: Climatronic 10A
17: Not assigned
18: Parking aid 5A
19: Not assigned
20: Uphill-Start off-Assist 5A
21: Not assigned
22: Air blower for Climatronic 40A
23: Front power window 30A
24: Cigarette lighter 25A
25: Rear window heater, Auxiliary heater 25A
26: Power socket in the luggage compartment 20A
27: Fuel pump relay 15A
28: Not assigned
29: Engine control unit, Crankcase ventilation heater 10A
30: Injection valves (diesel engine) 10A
31: Vacuum pump 20A/Control unit for Haldex coupling (4x4) 5A
32: Rear power window 30A
33: Electric sliding/tilting roof 25A
34: Not assigned
35: Anti-theft alarm system 5A
36: Headlight cleaning system 20A
37: Front seat heating 30A
38: Not assigned
39: Control unit for automatic gearbox 20A
40: Air blower for heating and air conditioning 40A
41: Rear window wiper 15A
42: Wipe wash pump for windscreen 15A
43: Towing device 15A
44: Towing device 20A
45: Towing device 15A
46: Heated windscreen washer nozzles 5A
47: Relay for auxiliary heating 5A
48: Not assigned
49: Light switch 5A
Yes revs going on and off same with speedo loud bleeping constant abs flashing anti skid flashing
