Where is the best place to pull audio power cable through the bulkhead....
For a fabia, anybody know, doesnt seem alot of options tbh....
Unscrew and remove your glove box.
You will then see a grommet going through the bulkhead which pops through near to the pipe that feeds the rear washer jet. Could even be through the same grommet... I don't remember.
Anyway, this is the best place.
Anyway' date=' this is the best place.[/quote']
:iagree:
And in the event of tight spaces, drill a fresh hole (careful when breaking through to the other side (song? :D) and then silicone up a bit when cable is installed. :)
Lovely, i had fun fitting the tv head unit with the miles of wiring that comes with it, dont think my hands have ever been so cut up, but it looks the tits tho. I had to run a 30amp cable throught the said washer jet plug, but didnt play nicely, needed to sqeeze some silcone grease in the hole to get it to move easy, but it still pierced through the rubber at the engine side instead of coming through cleanly next to the tubing.
