Climate control
I dont think the cold air side of the climate is working.
Because im having problems with the car ive decided to check EVERYTHING.
Usually i have the climate set at 21 degrees,but today i set it to low{cold} for 10 minutes but the air was far from cold ,more like luke warm.
My previous octavia :wink: would have been freezing in less than a minute.
Or would it?
I cant remember.
:oops:
steve
Why set it to cold when its freezing outside??? Am I missing something here?
Obviously.
Did you read the bit about Problems and Checking everything????????????
I also noticed its a bit cold outside but if the climate control is'nt working
and the rear suspention is faulty ,
THEN I DONT WANT THE ****ING CAR.
Thanks for your help DGW?
Could someone please tell me if the climate should take 10 mins+ to get cold.
Or would it?
I cant remember.
:oops:
steve[/quote:63c608d3b9]
Steve,
The air con unit will not operate at temeratures below +5 degrees C so I image the outside temperature may well be below this value it has been were I live the last few days.
the coolest air to come out of the vents when air con is operating is said to be +5degrees at the least when operating
John
Thanks John.
Ill wait for the weather to pick up before adding it to the list .
I dont want the car now anyway.
Ive met more trust worthy 'DEALERS' in SOHO!
Steve
I'm genuinely sorry to have come across as unhelpful, Steve. :oops:
The air conditioning (Climatronic) in my 4x4 managed to produce really cold air when the outside air temperature was 93
Sorry Denis.
This poxy car has given me the hump.
Steve
